jgoecke
Nov 24, 2019Aspirant
404 error
I see multiple posts about this issue and even though is says the issue is solved I never really see a solution, or on that I can make sense of. Im not a tech idiot and really want to fix this. I see all this about setting the Orbi from Router to AP but see no way to do this. This 404 error is very annoying and really makes the system useless.
Yes, there have been dozens of posts. Each situation may be a bit unique. It will help if you describe:
- When do you receive the 404 error?
When browsing to any/every web site?
When browsing to the Orbi web interface?
Using Mac, PC, iPhone, Android phone (all of them)? - Exactly what is your Orbi connected to (brand/model)?
Is that device in "bridge" (passthrough) mode or router mode? - Is the Orbi in router or Access Point (AP) mode?
Thanks
- jgoeckeAspirantSeems to happen with all devices but mostly when going to a link inside another page. I can get to the homepage of a site but then a link to another part gives me the error. Apps like ESPN do not work either on phone and when I turn off WiFi it does. It is not set up as a bridge and I don’t know how to set up the Orbi in AP mode. I do have the WiFi turned off on my router. It is a zyXEL from metronet. I may be able to contact them to set up as a bridge router but would like to just change orbi to AP setting.
Orbi can be put into AP mode using the web interface. On the Advanced Tab
