Reply
Highlighted
Virtuoso
A question about 5GHz wireless channel setting
Admitedly I haven't paid much attention to the wireless settings in the management console, but I am aware my RBR50 is using channel 48.  When troubleshooting a different issue, I used wifi analyzer to see what was going on and found my neighbors wifi was stepping on my channel 48.  The channel setting in the Orbi came up this way after a cold start factory reset.  By comparison, the 2.4GHz radio channel is set to automatic, but the 5GHz only offers 4 choices strangely, but assume this is intentional and by design.  Any rationale for this, just curious?
Orbi RBK50 in AP mode, 100/20 Mbps VDSL2, Arris BGW210 gateway
Message 1 of 12
Highlighted
Virtuoso
Re: A question about 5GHz wireless channel setting
I moved the 5GHz channel from 48 to 44 and noticed a warning about wifi alliance and 20/40 MHz Coexistence.
Everything seems connected AFAIK but want to know if I need to switch it back.
Message 2 of 12
Highlighted
How far away is your neighbor?
5GHz channel doesn't travel well through walls and further.distances.
Netgear CM1000V2
Orbi RBR50 & (2)RBS50 V2.5.1.8
Message 3 of 12
Highlighted
Virtuoso
Next door. The homes are on 1/3 acre lots so can’t give precise measurement as I don’t know where in his house the router is . But it’s enough to register on the scanner tool.
You’re probably right that it’s not enough to be an interference issue but I’d just as well keep my side clean as possible.
Message 4 of 12
Highlighted
Guru
Before MESH and Tri band routers, the signel 5Ghz radio supported channels 36-48 and 149-165. Since the advent of triband, chipset mfrs split the 5Ghz radios into two, one channelization set for 36-48 and the 2nd 5Ghz radio set for 149-165. Now with the advent of MESH, Chipset mfrs use this "wireless backhaul" set on the 2nd 5Ghz radio, hidden and just used between the remote satellie(s) and the base router. Thus only the 1st 5Ghz radio is made user available and configurable on channels 36 - 48 only. Mostly by design and govt communication rules mfr have to follow. DFS is slowly coming to routers. This add more channel availability to wifi routers. Not sure if current gen Orbi will see DFS. Probably next gen.
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 5 of 12
Highlighted
Virtuoso
Interesting. This may explain the phantom signal I’m seeing on channel 157. Anyway to know for sure the exact channel backhaul is using?
Message 6 of 12
Highlighted
Guru
Power OFF the Orbi while you watch the scanner app. If it disappears, then re-appears after you turn ON the Orbi, you'll know.
Message 7 of 12
Highlighted
Virtuoso
Good idea, but that wasn't it.  Unfortunately the Amazon tablet isn't able to see the newer intermediiate channels and it would have made more sense for NG to choose one of those less used channels for backhauling traffic   I'll see if I can get my hands on a better tool to check.
At least moving the primary traffic to channel 44 is good enough to have a clean signal there.  As for what else is pushing a signal, I suspect the Arris router is still transmitting even though the radios are supposedly turned off and the power output lowered.
Message 8 of 12
Highlighted
Master
Please check this post: https://community.netgear.com/t5/Orbi/5Ghz-channels/m-p/1538610#M26710
And this one: https://community.netgear.com/t5/Orbi/Understanding-Orbi-Radio-Fronthaul-Backhaul/m-p/1671092#M46569
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 9 of 12
Highlighted
Guru
Well you can turn OFF the Arris modem/router and see if the scan app shows any differences. Then turn it back on.
There are to places I think for Arris, there is a enable or disable SSID then I think there is a disable WiFi broadcast somewhere in the advanced settings. Ensure that the Advanced WiFi broadcast settings are disabled.
Some channels can't be used by chipset Mfrs so NG and others have to abide by what is regulated by the FCC.
Message 10 of 12
Highlighted
Virtuoso
Yes, I did three things I did on the Arris. One was to manually set the channel to one of the non standard ones, then I lowered the transmit power to 1%, and finally turned the radios off.
I’ll search if there’s a further way to determine the origin of the signals I see.
Thanks!
Message 11 of 12
Highlighted
Virtuoso
Thank you. The backhaul channels must be the ones I see in the 149+ range. No SSID.
The provided links are awesome.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 13072 views
  • 4 kudos
  • 4 in conversation
Announcements
