- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Android connectivity issue on Pixel
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am facing strange issue with my Orbi wifi connection on Google Pixel 3 XL. Pixel connects to wifi and i can browse with chrome but apps are not connecting to internet. When I connecct mobile data it is working fine no issue. I tried connecting to several other wifi and it works fine no issue.
any help in solving this mystery is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Android connectivity issue on Pixel
What FW is currently loaded?
Using any custome DNS on the Orbi router or letting it detect DNS from ISP?
Is this the only device that exhibits this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I changed dns to Google dns yesterday and still same issue.
It is happening only on pixel 3 xl.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might contact Google about this and let them know what your seeing and that this is the only device giving a problem with the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You tell them this is the only device doing this?
Possible wifi problem between this device and orbi.
Is the Google device updated fully?
What happens if you temporarily disable WPA security on the Orbi and connect the Google device and test? Apps get any internet?
After trying this, set back to WPA2 and AES only and test.
Can try this and see if this helps any:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-...
https://community.netgear.com/t5/Orbi/Have-to-keep-rebooting-my-RBR50/m-p/1658603/highlight/false#M4...
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know what you find out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got another mesh router and it is working on there. Totally clueless why orbi and pixel 3xl . I wish there is a log which I can see to make some sense
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am on Android 9.0. apps are not able to connect to the internet. They just throw error message that check internet connection.
I do need help. I am at the point where I can not return phone or can not return my orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue in my Pixel XL first gen.
Do you have other Android devices on Pie or are they previous versions of Android?
My big issue is an app for my fireplace (yeah, first world problems). The developers of the App have not updated to support Pie so the app itself cannot detect the WiFi state from the phone. I contacted the developers which seem to be 2 guys in China and they've admitted the fault.
Your situation may be different, but thought I'd share my issue.
I'm still very angry with NG over the Orbi Firmware and the other issues, but this may not be on them. The Google support team is very long but generally unsophisticated at the first 2 tiers and will blame anyone they can.
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
