Reply
BRS WAN LAN conflict
paulcwr
Tutor
for some reason, even though my Orbi with 2 satelites had always worked fine, since about mid october, whenever on an apple device (never tried on a PC since i don't own one), whenever I go to a site that uses https, the orbi seems to append the suffix "brs wan lan conflict.html" to the web site adresse and I get a web page asking me to log in and enter a user name and password.  this page seems generated by the orbi since it is the same regardless of the site when I am intending to go (eg ebay, amazon, etc.). This both on iphones, ipads and my mac.  My setup is that I have a dsl modem+router in which I plug in the orbi router, and this one acts as a wifi hub and also provides ip connetivity to two satellites.  This setup worked fine for over 6 months and overnight stopped working.  Does anyone have any idea how to fix this really annoying issue?  thanks in advance for any help.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 9
Accepted Solutions
Guru
Re: BRS WAN LAN conflict
What FW is currently loaded?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 9
All Replies
Guru
Modem Combo Units:
Couple of options,
Message 2 of 9
ekhalil
Master
@paulcwr wrote:
.....  My setup is that I have a dsl modem+router in which I plug in the orbi router, and this one acts as a wifi hub and also provides ip connetivity to two satellites.  ....
Please make sure that your "dsl modem+router" is set to bridged mode and is not acting as a router, if you have the Orbi set to "Router Mode"
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 3 of 9
paulcwr
Tutor
This worked.  I disabled the daisy chain functionality and now I can visit all web sites, even those using HTTPS without having this BRS WAN LAN contflict and the mysterious login page.. thanks for your help.
paul
Message 4 of 9
ekhalil
Master
I think that this worked only temporarly since disabling Daisy Chain causes a system restart. I expect that you can see the issue again when a new IP address conflict will occur next time you make another system restart (on next software update for example Smiley Happy )
I suggest that you solve the root cause of the issue instead.
Message 5 of 9
paulcwr
Tutor
thanks for helping.  I am sorry to ask but I am not too competent on dsl modem programmeing so how do I solve the root cause issue?  can you please point me to a step by step guide? thank you
Message 6 of 9
ekhalil
Master
What is the brand and model of your DSL modem+Router? Do you have a manual for it so we can check how to change the configuration to bridged mode?
Message 7 of 9
Guru
If you can find a manual or online support site information for the ISP modem, you an ask your ISP for help and information regarding bridging, IF the modem supports it.
Message 8 of 9
Guru
Glad the change worked.
If everything is working, you might run it for now and leave the system alone. Maybe no need to bridge the modem...
paul
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 15524 views
  • 0 kudos
  • 3 in conversation
Announcements
