- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BRS_wanlan_conflict.html with orbi - and connecting to webpages with often 404 (page exists)
- Mark as New
- Bookmark
- Subscribe
- Permalink
ATT modem (uverse)
Orbi.
connect the orbi to ATT directly per instruction.
When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that says no such webpage exist
The web adress is followed by - BRS_wanlan_conflict.html
It prevents me from using certain webpages.
FOUND NO SOLUTION ON COMMUNITY.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BRS_wanlan_conflict.html with orbi - and connecting to webpages with often 404 (page exists)
Your ISP modem will already have a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@greenkaczka wrote:ATT modem (uverse)
Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@greenkaczka wrote:When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that says no such webpage exist The web adress is followed by - BRS_wanlan_conflict.html
Would it be convenient for you to post a screen shot of this message? (i.e. make a screen capture of the message. save it to a PNG or JPG file. then attach it to a message.) If I read the Orbi web pages correctly, there should be an IP address included in the message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Your ISP modem will already have a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Orbi.
Thank you!!!!!!!! Following the Orbi manual instructions on setting the Orbi router to AP mode SOLVED THE PROBLEM. The hardest part was remembering my password to gain admin access my Orbi router -- I had to reset the password with the serial number of my Orbi Router after several failed attempts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi.
This happens when your ATT modem is a router and your Orbi is also a router, causing the Double NAT issue @FURRYe38 described. You just need to put your Orbi in Access Point (AP) mode, so it provides just your wireless network, and leave the router function to your ATT modem: https://forums.att.com/conversations/att-fiber-equipment/brs_wanlan_conflict/5e728051c17a064135f077a...
From FURRYe38's reply here are the instructions to configure your Orbi in AP mode:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to write down important information for safe keeping and remembering.
Glad you got it working.
Please mark your thread as solved so other will know.
Enjoy.
