jaysam
Nov 09, 2019Aspirant
Cannot connect to the internet with Orbi RBK50v2
Trying to connect to the internet, using our Vodafone (NZ) router, Orbi is all on and good to go but cannot connect to internet. It can't be that hard! I have tried manually entering all the IP info and still no luck. Could Vodafone be blocking Orbi? Driving me crazy as I have read other posts and they dont make sense or dont work. And yes i have reset the modem....a number of times!
Thanks Sam
- ekhalilMaster
What is the type and model of the Vodafone router please?
- ekhalilMaster
jaysam wrote:Hi It is a Vodafone Technicolor TC4400VDF modum and the router is Vodafone Ultra Hub PTC 295/17/002. Well that are the details I can see. Thanks.
Both those devices look to be routers which makes multiple routers in your network and could be the cause of the issues you’re experiencing.
- Please start by completely removing the Vodafone Ultra Hub PTC 295/17/002, and connecting Orbi directly to the Technicolor DOCSIS router. Please test with this configuration.
- Do you have access to the Technicolor router? You might also need to bridge it if it’s also a router. I see that it has two LAN ports and provides DHCP.
- Retired_Member
Looks like the Vodafone (NZ) router is a combo, meaning it's a modem and router. Not recommended with the Orbi.
You can try configuring one of them as a acess point.
Which came first the Orbi or the Vodafone (NZ) router?
- jaysamAspirant
The Vodafone router was first. Which is a Vodafone Technicolor TC4400VDF. Plus we have the Vodafone router atached as well.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jaysam wrote:Trying to connect to the internet, using our Vodafone (NZ) router, Orbi is all on and good to go but cannot connect to internet. It can't be that hard! I have tried manually entering all the IP info and still no luck. Could Vodafone be blocking Orbi? Driving me crazy as I have read other posts and they dont make sense or dont work. And yes i have reset the modem....a number of times!
Thanks Sam
Is the Vodafone Ultra Hub the ISP modem or is this just a router? If it's just a router and you have a modem infront of the HUB device, remove this HUB router device and connect the RBR directly to the ISP modem.
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry these other suggestions of the modem is a modem/router combo unit.
cn8476 wrote:I have the same problem at the moment (Vodafone Ultra Hub + Orbi RBK20). What seemed to work best for you?
Cheers
