- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot get Orbi RBK14 router to recognize ARRIS modem SB8200 DOCSIS 3.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi router worked well with an Arris DOCSIS 3.0 modem, but when I changed to a new Arris DOCSIS 3.1 modem, model SB8200, I cannot get the Orbi router to connect to the modem and internet. I have tried all the recommended setup efforts, including resetting the router. The satellites all sync well with the router; just can't get the router to connect with the modem/internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot get Orbi RBK14 router to recognize ARRIS modem SB8200 DOCSIS 3.1
Did you POWER OFF the ISP modem and RBR for 30 seconds, then power ON the modem and let it sync, then power ON the RBR and walk thru the setup wizard with a wired PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes on the powerup procedures, but I did the setup wizard via my cell phone app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you use a wired or wireless PC or laptop and connect to the RBRs web page there to walk thru the setup wizard?
Did the phone app give any indication that the RBR was not connected to the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The phone app just lists the internet connection as "offline."
- Mark as New
- Bookmark
- Subscribe
- Permalink
What are the RBRs LED colors when you complete the setup?
Please try setting up with a pc and see.
Swap LAN cable between the modem and RBR. CAT 6 cable is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
LED color is solid orange; does not go to blue. Any website or link suggestion on how to do setup via a wired pc?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should be able to connect a wired PC to the back of the RBR? Then use your web brower to connect to orbilogin.com or 192.168.1.1.
Review the user manuall for installation help and information as well.
