jeffish
Jun 03, 2019Aspirant
Connect to Apple Time Capsule Remotely on Orbi RBK43
Hello,
I switched from an aging Time Capsule to Orbi. I used to connect remotely to the hard drive on the Time Capsule and can't seem to access the drive anymore. I attempted to port forward but while trying to connect even locally using the Mac's connect to server, the connect hangs and fails.
The drive shows up as a sharedrive, however when I use the external IP and port the connection fails.
Has anyone connected to the Time Capsule? Separately, also have a WD MyCloud, without using their App, I was able to connect remotely to this. I haven't been able to connect either.
Thank you in advance.
- ekhalilMaster- Which port are you using to reach the drive remotely?
- Please activate UPnP in Orbi and ATC
- Check out this article https://support.apple.com/en-in/HT204618- jeffishAspirantUPnP is activated on the Orbi, the ATC does not have that functionality.
I have BackToMyMac set up, however I’m attempting to connect with a mobile device using either SMB or AFP.
I’ve tried a couple different ports including the ones listed on the UPnP Orbi page.- FURRYe38Guru - Experienced User
