GinaFitz's avatar
GinaFitz
Connecting Orbi to iAquaLink pool system
I am unable to connect my iAquaLink system to the Orbi network. I get as far as selecting the network and putting in my password. It just drops the network. I understand that the iAquaLink can only work with 2.4 MHz. Is there a way to ensure this is what Orbi uses or recognizes and pushes? I love the signal strength and got Orbi so a signal would reach the pool area... but can't connect the pool system.
  • I'm not familiar with the iAquaLink but I do have a similar Pentair WiFi system and I have no trouble with the Orbi. Do you use your iPhone to control the AquaLink? I suggest you do a factry reset of the iAquaLink then retry going through the iAquaLink system setup. Another thing you can try is to make an IP reservation of the AquaLink in the Orbi "Advanced" tab. Under the "Setup" you'll see a "LAN" setup section. When you click on that, it will open a page to allow you to add IP reservations for items connected to your Orbi.
    I've noticed that some remote systems take quite a long time to sync with the Orbi. Do not understand why that is but i've seen it with WiFi cams, etc.
    • GinaFitz's avatar
      GinaFitz
      Thank you for the reply.  I am trying to use iPhone.  This is first time we are trying to connect the iAqualink and I purchased the Orbi network because it seemed to be the only one with a signal strong enough to reach pool equipment.
      I understand that for some reason the iAqualink will only connect to a 2.4ghz network (not a 5.0) ... and that perhaps the Orbi network isn't combatible even though it is supposed to be "smart" enough to know what to send and I can't imagine 5.0 would even make it as far away as my equipment/iAqualink control.   I am not sure I understand making an IP reservation ... would the sytem have to be connected to do that (and would it potentially fix the ghz issue)?
      I am hearing a buzz that suggests Orbi won't work which would be too bad as it is best system it seems for my house.  Please if other suggestions -- or if anyone has been able to connect Orbi to iAqualink let me know.
      • tucsontico's avatar
        tucsontico
        Virtuoso
        You are correct that Orbi is "smart enough" to transmit both the 2.4 & 5 gHz bands. I have multiple items on my WiFi that are 2.4 gHz only (including my pool controller) and they have no problem connecting to the Orbi. Some of the 2.4 gHz items are outside my house (IP cams, pool controll, etc.) and quite a good distance from both the Orbi base station and the Orbi satellite.
        You can manually assign an IP reservation in the Orb software. You must know the MAC address of what ever you're trying to assign to a particular IP address. If the device is connected to the Orbi, it will be displayed in a list after you click on the "Add" button at the bottom of the "LAN Setup" page. If the device is not connected, when you click "Add" there is a  manual entry option displayed after the list of connected devices. Simply fill in the blanks (IP address, MAC address, Device Name) and click "Add". It will take about 30 seconds for the Orbi to reset the IP list but be patient and the Device will show up in the "Reserved IP" listing. After you do that, try to reconnect your iAquaLink by rebooting it (power off/power on).  Good lUck!
  • I had to get a separate 2.4G access point for iAquaLink to connect to (fortunately I have an Ethernet Port not too far from the pool equipment). I had no luck with getting it to connect to Orbi - having tried all of the suggested work arounds.
  • My work around- I used an old TP_Link Wifi extender, connected it to the Orbi network and created a seperate SSID for the pool equipment. Worked like a charm!
  • I have pretty much the same situation except my Iaqualink worked perfect for about 2 months, then all of a sudden as soon as I would try to open the app or login, it would get kicked off the network.  Iaqualink feels there's something about the mesh system that it tries to push 5ghz onto products that only accept 2.4 but that doesn't jive with the fact that accessing the app is the process that kicks it off the network.
    Jandy (owner of Iaqualink) sent their rep here, he  replaced the chip and the antenna, no change, we checked the settings to find that my orbi was inadvertantly set to auto on 2.4 so I changed it to channel 1.....no fix. The signal is full strength at the antenna as I am only able to get 25mb/s wifi here and it's full strength thanks to the Orbi, but whatever causes this handshake issue is unknown.
    As a 2nd to last resort I have turned my uverse 2.4 wifi back on (left the 5ghz off) and re-set the antenna to connect to the att uverse, even at a whopping 1mb/s it's working and has not kicked me out.
    To recap:  The Antenna will connnect to the orbi router and hold it's connection UNTIL you access the app and try to use it, THEN it kicks the connection (for me this is what is happening) I understand some of you aren't even able to get connected in the first place which is also strange)
    • Chuck_M's avatar
      Chuck_M
      Mentor
      Has this device EVER worked with Orbi?
      Can you tell us your Orbi firmware version?  This might be something that the beta firmware has resolved.
      Can you describe what the rest of your network looks like? (e.g. what hardware is upstream of the pool and/or your mobile device?)
      And finally what is the make/model of your cable modem?
      If all other potential causes arent there...
      In this case, I would try lowering the power of the 5G network to 25% -- forcing the Iphone to the 2.4g network by the pool and then trying a setup with your phone near your pool equiment.    Then increase the 5g power back to normal.
      • silver123's avatar
        silver123
        firmware V2.2.1.210
        It connected to Orbi fine but when you access the application to make changes to the pool settings it kicks it off the network
        I only had he Orbi running wifi until now, I Had to turn on the 2.4ghz wifi channel on the att router to get a connection that won't kick the iaqualink offline when I use the app
        When you say "upstream" what do you mean, is there an order to how devices are connected / level of importance for example?   I have 17 devices connected to the orbi, things like iphone X 2, ipad, roku tv X 5, computer, sonos X5, roomba, lutron, rainbird irrigation, garage doors.
        att router is 5268ac
    • ekhalil's avatar
      ekhalil
      Master
      silver123 wrote:
      ....................... my Iaqualink worked perfect for about 2 months, then all of a sudden as soon as I would try to open the app or login, it would get kicked off the network.  Iaqualink feels there's something about the mesh system that it tries to push 5ghz onto products that only accept 2.4 but that doesn't jive with the fact that accessing the app is the process that kicks it off the network.
      1. How do you see that the device is kicked off the network? Do you see it in attached devices in Orbi app or in web GUI and then it disappears?
      2. When you see the device in attached devices, what name does it have in Orbi and in the Iaqualink app?
        silver123
        ekhalil  On the antenna itself you can watch the wifi LED turn off as soon as you access the app on the phone (or computer)
        On the Orbi app you can see it in connected devices, it does take a few minutes to refresh then it goes away, and about 30 minutes later it pops back up and shows connected on the Antenna LED and it's listed in active devices (until you try to access the app again)
        read my experiments maybe that will give you more answers.
