jasonreams's avatar
Mar 24, 2020
Constant VPN reconnecting since upgrading to firmware V2.5.1.8
I was on I think a v2.3 firmware with 1 router 1 satellite. RBS50S and RBS50R. I bought a new RBS50S and it required a firmware upgrade. At least it looked required. I did the upgrade. Connected the other satellite. My work VPN has been solid for 10 months. I have had the Orbi I think almost 2 years now. No problems. New Satellite on other side of the house. I am WIRED and not using WIFI and now my VPN is constantly reconnecting. I am curious if anyone else has seen this. It is a CISCO VPN. I cannot share too many details on the VPN because of security reasons.
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update? IF this fails, try downgrading to last working version of FW.
  • Retired_Member's avatar
    Retired_Member
    this is your problem...V2.5.1.8
    get rid of it
  • I found the problem. At the same time of the firmware upgrade my company had a VPN issue and others saw the same problem. What a coinincidence. It has not happened since.
    • CrimpOn's avatar
      CrimpOn
      Oh, my. A problem NOT caused by firmware 2.5.1.8.  Thanks for sharing the resolution.
      VPN is becomming ever more important in this time of "Work from Home."
      Glad you found a solution.
    • FURRYe38's avatar
      Thank you for letting us know that you got it solved and it wasn't a problem caused by FW. :smileywink:
      FW usually isn't a problem. Application and configuration is more likely.
      Be sure to mack a backup configuration to file for safe keeping. Saves time if a reset is needed.
      Enjoy. :smileywink:
        Retired_Member
        there you go again...blind as usual....wake up please....
