- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disable bridge mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disable bridge mode
I'm trying to set up my new Orbi system. I have a Ubee gateway modem/router. When setting up, it keeps saying my ethernet cable isn't connected & it is. I called Netgear & 28 hours later the only response I've gotten is for a survey. Online searching shows I may be in bridge mode & need to disable the router from the gateway. I've called my internet provider & they say "just plug in & everything works". Wrong. I've logged into my modem's IP address, but when I disabled the bridge mode, I lost internet. Got that back, but now I am still stuck.
Any help & suggestions? I've spent hours on this--I'm obviously not a tech person.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disable bridge mode
@Louann wrote:I'm trying to set up my new Orbi system. I have a Ubee gateway modem/router. When setting up, it keeps saying my ethernet cable isn't connected & it is. I called Netgear & 28 hours later the only response I've gotten is for a survey. Online searching shows I may be in bridge mode & need to disable the router from the gateway. I've called my internet provider & they say "just plug in & everything works". Wrong. I've logged into my modem's IP address, but when I disabled the bridge mode, I lost internet. Got that back, but now I am still stuck.
There could be several issues here. First, is the only Orbi component the RBS40V?
If this is the case, then
- The Orbi Voice must be in "extender mode" as described in the installation guide:
https://www.downloads.netgear.com/files/GDC/RBS40V-200/RBS40V-200_QSG_EN.pdf - The UBEE must be in Router mode (not bridge mode)
- (to be honest) I am not certain that the RBS40V will connect to something over ethernet when in extender mode.
If this is not the case, then the Orbi router's WAN (yellow) port must be connected to the UBEE modem with an ethernet cable.
It would be helpful to know the model of Orbi router and UBEE modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would need to talk to your ISP and have them help you enusre the modem is bridge fully an no other ISP configurations are needed at the modem or on the RBR router if they require that.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
