Drakier
Mar 24, 2019Aspirant
Enabling VPN on RBK50 causes internet to disconnect
I just got the RBK53 today and so far really like it and the features it has. I have it all updated and configured to work really well within my network and using hard-wired backchannel for satelites. It covers my home great and so far there haven't been any problems, except one.
When I go into the Advanced Settings and attempt to enable the VPN Service, then my internet disconnects. I can no longer access websites or anything and get some strange errors in various clients when I attempt to access them. This is just normal internet from within the network and none of them are currently connected to the new VPN that was set up. As soon as I disable the VPN Service and apply it, my internet goes back to working. I'd really like to be able to use the VPN for when I'm away and want to get local access to my network (in addition to security for tunneling my data through my house).
Anyone have any suggestions or anything else I might be missing or try? I've already attempted to change the "mode" on it from Auto to "everything" option and neither seems to make any difference at all. I can't see any reason why enabling the VPN service (to allow it to receive and process VPN connections externally) would cause the WAN side to completely stop working.
Thanks!
- ekhalilMaster
That sounds wired, since enabling VPN should -as far as I know- not do anything to do with internet connectivity.
The only thing that I can think of is the DDNS settings, since VPN is directly related to the DDNS settings. What DDNS sevice are you using? What do you get when checking the status of DDNS (clicking on SHOW STATUS under the DDNS settings)?
- DrakierAspirant
First off, thank you for your reply!
I'm using the DDNS attached to no-ip.com. It all works fine, and when I "Show Status" I get a reply myddns-domain.com updated successfully at 05:52 PM, 03/24/2019
I was originally not going to use DDNS on the router since I have a client running on one of my machines which works fine. I'm guessing that DDNS must be enabled for VPN to work for configuration.
I'm also pretty stumped on this. I'm no newbie to this stuff and it makes absolutely no sense to me why it would take out the internet. The actual "Internet" tile on my home page shows as having a problem when this happens... so the router itself can clearly not detect the network when this happens.
- ekhalilMaster
Then I would think this can be a sort of data corruption in the VPN settings, and I'd try to factory reset the router as a first step if you have not already done this after getting the VPN issue.
- SennevdsAspirant
I have exactly the same problem.
When I enable the vpn service on the orbi all clients on the private network have problems with connecting to the wan side.
The vpn client itself has no problems. My Orbi is behind another router(provider) so maybe it's a double NAT problem but still strange- MavXDAspirant
Hi, I have the exact same problem, internet connection is not working as soon as I switch on the VPN. Can anyone help?
Sennevds wrote:I have exactly the same problem.
The vpn client itself has no problems. My Orbi is behind another router(provider) so maybe it's a double NAT problem but still strange- ekhalilMaster
- Will the issue start happening when enabling VPN or when you have a VPN client connected to Orbi?
- When you have a VPN client attached to Orbi, what IP address is assigned to this VPN client? You can check this by going to "Attached Devices" list in the bottom of the web GUI.
- What is the type and model of the ISP modem/router to which Orbi is connected?
- What LAN IP range are you using in Orbi?
