whittle's avatar
whittle
Guide
Jun 18, 2018
Guest network in AP Mode?
I'm thinking about putting a router in front of my RBK50 and running the Orbi system in Access Point mode.  Do you lose access to the Guest Network feature in AP mode?
Thanks much.
whittle
  • FURRYe38's avatar
    I believe so since the WAN port become a LAN port and the separation beteen WAN and LAN is disabled which Guest Network is dependent upon the WAN side being used.
    Thanks much.
    whittle
    Hi Whittle,
    Yes you can. That is exactly how I have mine setup right now. My FIOS router is handling all the DHCP, DNS, firewall stuff and my ORBI is running in AP mode only. You can enable the GUEST wifi on the ORBI without any issues. You do have to use the web interface (orbilogin.com) to turn on the guest network. You can also use the android app (netgear genie) to turn the guest network on/off. The option to do so on the IOS app is not available when you turn on AP mode, for whatever reason.
    Moses
    • whittle's avatar
      whittle
      Guide
      Thanks very much Moses.  I think I will give it a go.  Just for reference, what Orbi firmware are you running?  -whittle
      • Mozez's avatar
        Mozez
        Guide
        Hi Whittle,
        My ORBI router is currently on 2.1.4.10.
        Moses
  • FURRYe38's avatar
    Thanks, I'll keep this in mind. I guess NG solved the Guest Network with WAN issue while in AP mode. Good to hear.
