Orbi WiFi 7 RBE973
Reply
Has the Netgear Orbi RBK50 got mac filtering enabled and if so how can i disable it ?
darrenmilkins
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Accepted Solutions
Guru
Re: Has the Netgear Orbi RBK50 got mac filtering enabled and if so how can i disable it ?
Access control option and you would uncheck the Turn access control on to disable the filtering.
Message 2 of 4
All Replies
Guru
Message 2 of 4
darrenmilkins
Thanks very much, I have unchecked the box and it now says access allowed to all new devices, so I'll give that another go with the device I'm trying to connect!
Message 3 of 4
Guru
Should help.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5193 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
