- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How does satellite ethernet connections work with and with ethernet backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
I set up my orbi and had a general question about the ethernet ports on the satellite. I assume these act to take internet access from the wireless connection and clients connect through there. My downside is twofold. First, The main router only has 4 ethernet compared to my previous 5 so I need to get a small switch to expand this a bit. Second, the satellite orbi ended up right next to my office computer which has wired ethernet access. I was thinking about connecting the ethernet to do ethernet backhaul and was wondering if this would then cause the satellite orbi to act as a wired switch so that my devices in my office aren't forced to go over the wireless connection. This would allow me to replace the switch I currently have there and use it to expand the ports on the router.
As a side question...I noticed my PC which connects to the router through a switch now takes quite a long time to discover the network to the point where it has internet. Is this just because I haven't set up a static IP like I used to have or is there something else I should look into?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How does satellite ethernet connections work with and with ethernet backhaul
This Kb shows all the ways you can set up the backhaul.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren,
Thanks for the link buy that wasn't really my question. I understand that the wired backhaul can be done and I might try this. What I was wondering is IF I connect via this method are further devices connected to the Orbi satellite effectively wired ethernet to the main router? I guess the real question is is there any difference between connecting a computer to a switch connected to the Orbi router vs. connecting a computer to the satellite Orbi connected to the main router via the ethernet backhaul.
I hope this makes sense. I am basically wondering if I can get rid of the switch that is connected to my orbi router and instead just use the satellite as a switch.
Router---(wired ethernet)---Satellite---(wired ethernet)---Computer
vs.
|---(wired ethernet)----switch---(wired ethernet)---PC
Router ---|
|---(wired ethernet)----satellite
Hopefully my ASCII art shows up ok...but the core of the question is if the satellite connected to the router performs the same as a switch connected to the router for wired devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes the other ethernet ports on the satellite should provide connections like a switch if I am understanding your question correctly.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:I set up my orbi and had a general question about the ethernet ports on the satellite. I assume these act to take internet access from the wireless connection and clients connect through there. My downside is twofold. First, The main router only has 4 ethernet compared to my previous 5 so I need to get a small switch to expand this a bit. Second, the satellite orbi ended up right next to my office computer which has wired ethernet access. I was thinking about connecting the ethernet to do ethernet backhaul and was wondering if this would then cause the satellite orbi to act as a wired switch so that my devices in my office aren't forced to go over the wireless connection. This would allow me to replace the switch I currently have there and use it to expand the ports on the router.
It's simple.
Power off RBS50, connect lan cable from the RBR50 to RBS50 port 1 then power on RBS50. Satellite will be configured default as access point. Other lan ports can be used like a switch.
