Pratyay6's avatar
Pratyay6
Follower
May 31, 2017
How to setup Orbi system with existing routers
I have an existing home network with 4 routers, two netgear AC750s and two from another manufacturer. I have them connected with one AC750 as the master with DHCP turned on, and the others connected LAN-LAN with it. Now I want to include netgear orbis in my network. What is the most effective way to do it, without doing away with my existing routers ?
  • Hello Pratyay6
    All you would need to do is plug orbi into one of the routers and then enable AP mode.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Pratyay6
    DarrenM
    • TraptPatriot's avatar
      TraptPatriot
      Hi Darren,
      Would putting the Orbi in AP mode disable the DHCP or any other routing functions on the Orbi? Thanks!
      Dan
  • DarrenM's avatar
    DarrenM
    Hello TraptPatriot
    Yes it would then just be giving you the wireless functions and the Ethernet would be a switch basically.
    DarrenM
