philtully's avatar
philtully
Is it possible to connect RBS50Y to either an RBR50 and/or RBS50 using Ethernet backhaul connection
I currently have an RBR50 base and 2 RBS50 Satellites connected with wired ethernet backhaul connections.  I would like to add an outdoor RBS50Y in the same method.
Is this supported?
I understand I need to keep this unit and wires protected from significant weather.
    The RBS50Y has no ethernet jack.  Wired ethernet backhaul is impossible.
  • FURRYe38's avatar
    Possible.
    Might enable Daisy Chain on the RBR first.
  • CrimpOn's avatar
    CrimpOn
    • philtully's avatar
      philtully
      Thanks for the info...I was still looking at solutions for my outdoor wifi access.
      It looks like a weather proof case for a RBS50.
      • CrimpOn's avatar
        CrimpOn
        You might send a private message to Mstrbig (by clicking on his screen name).  He has posted several times about installing satellites outdoors with enclosures.  I do not recall seeing reference to any specific products or where he got them.
        Such as this post: https://community.netgear.com/t5/Orbi/Looking-for-Outdoor-POE-Extension-for-Orbi-Mesh-in-Home/m-p/1970121
        As you can tell from the messages, it is often more convenient to install outdoor access points that get power over the ethernet cable (PoE).
        Good Luck
