Orbi WiFi 7 RBE973
Reply
No internet connection only in part of the house
Caiteb
I have the Orbi and router system and it’s is not connecting to the internet downstairs. I have WiFi access upstairs but it won’t let anything connect to the WiFi downstairs
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: No internet connection only in part of the house
What is the setup of your orbi satellites in your home? Do you get signal downstairs just no internet connection?
DarrenM
Message 2 of 5
Caiteb
I was able to fix the problem. But yes I was able to get the signal downstairs but it kept telling me there was no internet connection.
Message 3 of 5
Guru
How did you fix the problem?
Message 4 of 5
Caiteb
I had to do a hard reset on the router and the satellite and then had to do a new set up through the orbi app since I was not able to connect to the internet even though the signal came through.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1578 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
