RLymburner's avatar
RLymburner
Odd ping spikes during online gaming (& streaming Netflix) with Orbi RBR50 - lag but no packet loss
My son's computer connects wireless to Orbi mesh 5G but he's having network trouble with online gaming. During games (CS Go/Rocket League/etc), he'll lag horribly which kills the experience. Router is Netgear Orbi (RBR50) in "router mode" with latest firmware (V2.2.1.210) Service is Verizon Fios Gigabit (no Verizon router, just the ONT). Speedtest at his system shows download speeds of 120-150 Mbps and 14ms ping.  I am connected hard-wire and do not exhibit the ping spikes.
Test on his system:
C:\>ping -n 30 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data
Reply from 8.8.8.8: bytes=32 time=8ms TTL=123
Reply from 8.8.8.8: bytes=32 time=10ms TTL=123
Reply from 8.8.8.8: bytes=32 time=11ms TTL=123
Reply from 8.8.8.8: bytes=32 time=1979ms TTL=123
Reply from 8.8.8.8: bytes=32 time=12ms TTL=123
Reply from 8.8.8.8: bytes=32 time=7ms TTL=123
Reply from 8.8.8.8: bytes=32 time=27ms TTL=123
Reply from 8.8.8.8: bytes=32 time=1865ms TTL=123
Reply from 8.8.8.8: bytes=32 time=13ms TTL=123
Reply from 8.8.8.8: bytes=32 time=9ms TTL=123
Reply from 8.8.8.8: bytes=32 time=2647ms TTL=123
Reply from 8.8.8.8: bytes=32 time=32ms TTL=123
Reply from 8.8.8.8: bytes=32 time=14ms TTL=123
Reply from 8.8.8.8: bytes=32 time=1972ms TTL=123
Ping statistics for 8.8.8.8:
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 7ms, Maximum = 2647ms, Average = 292ms
C:\>tracert -d 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 5 ms 4 ms 5 ms 192.168.1.1
2 8 ms 12 ms 10 ms 8.8.8.8
Trace complete.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
    Can you try connecting his computer via wired LAN cable and test?
    Is the computer connected to the router or a satellite?
    • RLymburner's avatar
      RLymburner
      Bear with me, cursory knowledge of networking only.
      I'm not clear what the ISP modem is - the Verizon ONT is bolted to the wall downstairs and I couldn't discern a model number.
      Orbi is on main floor 50-60 ft. from this PC - stairwell physically located between computer & router but no electronics. 2 satellites hooked up on different floors (above/below). WiFi adapter nothing special, cheap $20 from Amazon (https://www.amazon.com/gp/product/B01KZGZ2U6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) . I downloaded & reinstalled drivers, but the Windows 10 drivers haven't been updated in 2 years.
      Regarding configuration, 2.4g is set to Auto-channel and its going to "9". Using an app I was able to detect pair of neighbors using channels 1 and 6. On 5g, the channel is set to 48 and shows "36+40+44+48(P)". Security setting is WPA2-PSK [AES]
      Router firmware is V2.2.1.210 and son's computer connects to the router, not the satellites.
      When I connect his PC via cable, the lag disappears and ping is consistent 4-5ms and he's happily gaming again.
      I have not done these steps yet. Tough to spend too much time troubleshooting with the family around & Christmas looming! Give me another day or two to report.
      • FURRYe38's avatar
        Try setting 2.4Ghz to channel 11. 9 is a sub channel and not a primary channel.
        Try some of the suggestion when you get time.
  • RLymburner wrote:
    My son's computer connects wireless to Orbi mesh 5G but he's having network trouble with online gaming. During games (CS Go/Rocket League/etc), he'll lag horribly which kills the experience. .............
    What other wired devices do you have connected to Orbi? Does disconnecting wired devices have any effect on the latency you now see with gaming?
      RLymburner
      Let me come up with a network map, something is fishy.  My main computer, hard-wired, is no longer reporting expected download speeds.  While going through the Orbi menus, I saw the following speeds: (I expect up to 860 Mbps on Verizon Fios Gigabyte service)
      SpeedTest Results: 12-13-18
      Download:525.65Mbps
      Upload:858.53Mbps
      but on retests, I have dramatically slower throughput.  Not sure why the huge drop, my daughter upstairs listening to spotify, but everyone else sleeping.  What gives?
      Download:83.50Mbps
      Upload:94.36Mbps
