Orbi WiFi 7 RBE973
Reply
Only some devices with DNS problems
CR-sound
This may be a little different than the current DNS issues discussed...or maybe not. Most of my devices are connecting with no problem (3 Windows 10 computers, a Windows 2012 Server , 4 android phones, lots of smart home devices, couple tablets). Yesterday, I turned on  4 Windows machines that had been  on the network before, but were off. They would not connect,  DNS server not responding. This was the case whether connected via Wifi or Ethernet.  I could connect with the Wifi from the Comcast /Xfinity cable box/router. I prefer, of course to connect to my Orbi mesh network. Seems odd that some machines connect, some don't.
Orbi firmware v2.7.2.104...and btw, I have checked several times this AM and  the Orbi app (android) was unable to tell me whether new firmware was available, "There was a problem checking the firmware."
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Guru
Re: Only some devices with DNS problems
What mode is your modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can manully update FW to the RBW if it needs to be udpated.
Message 5 of 8
All Replies
CR-sound
BTW: I did reboot the router.
Message 2 of 8
Guru
Has both RBR and ISP modem/ONT been powered OFF for 30 seconds then back ON with the ISP modem first, then RBR?
Does checing FW updates on the RBRs web page show anything?
Message 3 of 8
CR-sound
Checked from the desktop access. I have  2 RBS 50s and an RBS50Y (outdoor satellite) with no firmware updates required. The RBR50 shows no firmware update available. The RBW30 satellite  has current firmware of   v.2.5.0.4 and shows update failed. The units I was unable to get DNS on were connecting via an RBS50 trying both wifi and  ethernet.
BTW: the units with the DNS issues connect to the local network and server  domain with no problem.
I have not recyled the Comcast router;  they list it as Technicolor CGM4140COM.
RBR50 settings include allowing new devices to connect.
Message 4 of 8
Guru
Couple of options,
Message 5 of 8
CrimpOn
Guru
You've probably already checked, but:
  • These 4 Windows computers were on the Orbi network previously?
  • Their IPv4 properties say to get IP address, subnet mask, gateway, and DNS server using DHCP?
  • What does the command ipconfig /all report for the ethernet and the WiFi interfaces?
    (obviously one at a time, depending on how they are connected.)
Message 6 of 8
CR-sound
I ended up  setting the Orbi in Access Point Mode...The Comcast/Xfinity modem is designed, it seems , to be really hard to tweak.
Seems OK now.  Thanks!
Message 7 of 8
Guru
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1609 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
