Reply
Orbi Placement
Pistol1957
Follower
Orbi Placement
Is is okay to place the Orbi & modem in an enclosed cabinet or closet?
Message 1 of 4
Re: Orbi Placement
its prob best not to as you may effect coverage and connectivity
Message 2 of 4
TomMac
Guru
Re: Orbi Placement
Any time you add more walls / materials between the main unit and the sat, you'll be cutting down on signal..
That said...in my case a stick built home.... my sat is 40 ft away from the main and it did end up in a closet on a self ( wife didn't want it on her work desk ( happy wife, happy life ))
Tests before and after showed no diiference with  transfer rates as I could tell.
Morse is faster than texting!
Message 3 of 4
fliparagon
Initiate
Re: Orbi Placement
Agree with the previous posts about adding more walls/doors just degrades signal ....
... but I too also have the base router in a pantry in the garage and have noticed no degradation in signal either.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5623 views
  • 2 kudos
  • 4 in conversation
Announcements
