Orbi WiFi 7 RBE973
Reply
Orbi RBK23
Morikid
Orbi RBK23
Just a general question, whether the RBK23 suitable for a 500mbps incoming service, or will the RBK50 would be better, its a medium size house with a garden room.
Thanks
Message 1 of 10
CrimpOn
Guru
Re: Orbi RBK23
They are different products.
  • The RBK50 has one router and one satellite.  The RBK23 has one router and two satellites.  In a medium size house, this may not make a significant difference.
  • The RBR50 (router in the RBK50) has three ethernet LAN ports. The RBR20 (router in the RBK23) has one ethernet LAN port.
    This is not a significant difference because that port can be connected to a cheap gigabit switch to allow many devices to be connected.
  • The RBK50 has separate radios and antennas for the 5G WiFi backhaul channel, which produces a theoretical maximum backhaul rate of 1.3GB.  The RBK23 uses the client radios and antennas for 5G WiFi backhaul and has a theoretical maximum backhaul rate of 833mbs, which is shared with client devices.  If the router and satellite(s) were connected using ethernet cables for backhaul, there would be no significant difference.
I doubt most users would  notice a difference between these products unless they intend to connect a very heavy usage device to the satellite over 5G WiFi and expect to backhaul that traffic over the WiFi link to the router.  There is no chance that such an application will realize 500mbs of actual usage in that scenario.  I don't think the RBK50 would either, but it would do more.
Sorry not to be more help.
Message 2 of 10
Guru
Re: Orbi RBK23
What is the Mfr and model# of the ISP modem you currently have?
Thanks
Message 3 of 10
Morikid
Re: Orbi RBK23
Thank you for the insight of the product & capability. I am UK VIRGIN MEDIA services on a 500mbps service. Their hub is a smart hub 3, but in my opinion & research that hub has poor wifi ping as soon as you move out of the Room the router is in. Thought that the RBK50 would be ideal but costly !! That why I was looking at the cheaper RBK23.. if that make sense 👍🏼😊
Message 4 of 10
Morikid
Re: Orbi RBK23
Virgin Media Smart hub3, at the router using my iphone 10, I get about 400-530mbps on wifi. Brilliant, but everywhere else in the house it ranges from 30-80mbps. Having read about the capability of the Orbi 23, thought that might improve my home wifi generally. As my service is 500mbps, the RBK23 is rated ideal for 200mbps.. thats means although i have 500 at my router, if using RBK23 I would be limited to a 200mbps !! Not sure
Message 5 of 10
Guru
Re: Orbi RBK23
Ok having two routers on the same line may cause some problems. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would go for option #3 first.
Message 6 of 10
Morikid
Re: Orbi RBK23
Best option in my opinion would be use Virgin hub in Modem mode only as I am not brilliant about configuring routers & use the Orbi Router & connect the orbi satellites to it . However I will read the links that you have supplied to gain knowledge. Thank you for all the help. Now need to decide Which orbi to buy ....
Message 7 of 10
Guru
Re: Orbi RBK23
Yes modem in modem mode only would be best. Contact your ISP for help regarding this.
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Sys...
Good luck.
Message 8 of 10
Morikid
Re: Orbi RBK23
Thank you for all your help
Message 9 of 10
Guru
Re: Orbi RBK23
Good Luck. Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1093 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
