Orbi WiFi 7 RBE973
Reply
Orbi RBK40-AC2200
williamsdcx
Orbi RBK40-AC2200
I have Orbi RBK40 running firmware 2.2.1.210.  Ever since the firmware upgrade my MyQ Chamberlain Bridge (MyQ-965) and garage doors are not responding.  I can open and close the garage doors through the MyQ app.  However the homekit status is listed as "No Response".  Previous Orbi firmware did not have any connection issues and Chamberlain Garage Doors functioned well with Apple Home Kit.  I have seen work around firmwear listed in other discussion threads however there firmware version is previous to what I am running.  When will a firmware upgrade for the RBK40 kits?
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 9
Guru
Re: Orbi RBK40-AC2200
Are they showing as connected to the Orbi at all?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-...
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
Might see if this works any:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649457...
Message 2 of 9
williamsdcx
The MyQ Chamberllain bridge shows as connected to the Orbi.  Also I can control the garage doors using the MyQ app just not home kit. MIMO, Daisy Chain are disabled.  Fast Roaming is turned on.  One of the Netgear reps had me disable Daisy Chain to give my system more stability since I have only one satellite running. (This was before update to FW.210)
Message 3 of 9
williamsdcx
IPV6 is also disabled.
Message 4 of 9
Guru
Is the check mark in the Daisy Chain or not checked? In this version of FW, the check mark needs to be on Daisy chain to disable it, as the behavior is reversed for some reason on this version of FW. However I presume this may not do anything.
I see others with Homekit issues on this version of FW as well...
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-HomeKit-Issues/td-p/1654959/jump-to/first-unr...
Message 5 of 9
williamsdcx
Thanks for the input on the reversing of the daisy chain function.  I will check the box to disable daisy chaining until new FW is received.
Message 6 of 9
Guru
Let us know if this helps any...
Message 7 of 9
williamsdcx
Chrcking the daisy chain box to disable the function did not improve the response of the MyQ Chamberlain component response.  Since you are closer to this issue than I have been are our friends at Netgear working on a fimware upgrade?
Message 8 of 9
Guru
I can only say that maybe reverting back to prior working version of FW may help. I don't have information regarding new FW updates.
@Christian_R
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1462 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
