- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR40 - not able to switch to AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
The instructions for 'logging into the router' to change it to AP are incorrect on this site and elsewhere. I cannot log into the orbilogin.com using 'admin' or 'passord' or my Netgear login or ANYTHING!
I have an AT&T Pace modem/router; first, there is no LAN port (what year is this?) per the instructions. Only Ethernet or Broadband. Ethernet is plugged in, I've turned off the wi-fi from the AT&T signal (so now the TV downstairs which can't be hardwired has no internet), and Orbi can't be shifted to AP mode as all the instructions say to do because I can't get in. So right now Orbi is as useless as the wifi signal it's suppose to carry! WHY can I not log on? Who has done this and can share what might be wrong? I'm using a PC, Chrome, it's up to date..Orbi firmware is up to date, I don't know what else to do but ship it back to Netgear. And it's not funny cuz this Orbi mated just fine with Spectrum's modem/router combo, no dicking around with 'modes'. None of it makes ANY sense. See the attachment from the Netgear site...this is the dumbest thing I've ever seen!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR40 - not able to switch to AP
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would factory reset the RBR and wire connect a PC to the RBR and walk thru the setup wizard, this time write down all important information. You should be able to access the UI and advanced tab/advanced settings/router and AP mode. I would not have the RBR connected to the ISP modem during this process...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Bonzoid wrote:The instructions for 'logging into the router' to change it to AP are incorrect on this site and elsewhere. I cannot log into the orbilogin.com using 'admin' or 'passord' or my Netgear login or ANYTHING!
Looking at the product description of the Orbi RBR40 (https://www.netgear.com/images/datasheet/orbi/RBK40.pdf), the Wide Area Network (WAN) port on the back is the one with Yellow around it, the Local Area Network (LAN) ports are the three ethernet jacks next to the yellow one. It is the Orbi people are suggesting that you connect to, not the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Or you are doing something wrong.
If you want to put a router into AP mode, it can be easier to do this "off line". Do what the manual advises, configure the Orbi router before you connect it to your modem.
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
Read the section Use the Router as a WiFi Access Point.
2019. Check the manual. (See above.)
Er...... or maybe you are doing something wrong.
The manual explains what to do, but your messages suggest that you may not have got that far, so let me add another important bit.
As this is a router that you want to put into AP mode, there is probably a modem router sitting in front of it. You need to get the modem router to forget its misspent past with the old router. Among other things, that means rebooting the network.
After the Orbi is in AP mode, restart your network in this sequence:
- Turn off modem/router.
- Turn off Orbi router and computers.
- Turn on modem/router. Wait 2 minutes for it to connect.
- Turn on the AP-mode router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What about the separate WAP that came with the AT&T router? That should be left out of the equation, yes? Seems if Orbi is my WAP why would I use theirs?
Again, my thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Bonzoid wrote:
This is the best answer yet...in plain English you point out the problem: that Orbi needs to be configured first. Not a mention of that in any instructions I’ve seen.
I don't know what you read, but it is clearly – well sort of clearly – laid out in the manual in the section I pointed to, which is all about Access Point mode.
It is impossible to say anything about this based on the minimal information you have provided. Your first message is all rant and minimal detail, with a failure to understand what a WAN or LAN port looks like. Not a good start for anyone trying to help.
What is this AT&T router? What is this "separate WAP"? The model numbers?
@FURRYe38 did ask.
We don't really know why you want to put the Orbi into AP mode.
