- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR43 with TDS Fiber
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m currently having internet issues with TDS fiber service. I pay for 300mb fiber but keep getting ~150-160mb from Orbi. I’ve tested hardwiring directly from Cat5e outlet to laptop, which gives me 300mb (All the speed test was done on Speedtest.net.) Does anyone know why the speed is reduced through Orbi? And is there any ways that I can get the right speed via Orbi? This is frustrating.
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR43 with TDS Fiber
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Swap LAN cables between the ISP modem and RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It’s running the lastest firmware (V2.3.5.30), and I think it’s connected to an ONT that TDS provides and mounted on a wall in basement. Is there still Double NAT condition?
- Mark as New
- Bookmark
- Subscribe
- Permalink
if the ONT has a built in router, then yes will present a double NAT condition. IF not, then single NAT is present.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1 reset pinhole, 3 Lan ports (one of them is connected to a cat5e cable), 2 phone ports, and a power input. The indicators including 1 POWER, 1 CPU, 1 WAN, 1 PHONE, 4 LAN.
Please let me know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just found out that it is a "Calix" ONU (716GE-I), and I'm not sure if it's configurable for bridge mode..
