AdamGH's avatar
AdamGH
Guide
Oct 07, 2018
Orbi RBR50 - iPhone App Store/ESPN not working
Just set up my system and everything works great. WiFi has been extended throughout entire house. I have found two small issues.
- my App Store will not download new apps or update apps
- my ESPN app is not working on my iPhone. I haven’t found any other issues. Everything seems to be working fine.
I have read other threads and haven’t found anything.
Any ideas? I appreciate any feedback.
  • Looks like a bandwidth/throughput issue. How much speed can you get from your iPhone when connected to Orbi?
    • AdamGH's avatar
      AdamGH
      Guide
      I have plenty of speed. 57 Mbps down and 61 Mbps up.
      • ekhalil's avatar
        ekhalil
        Master
        Can be an issue in the iPhone network settings, can result from keeping the same SSID after changing the router. Try to reset your iPhone network settings:
        Open Settings > Tap General > Tap Reset > Tap Reset Network Settings
        If you're prompted to enter a passcode, enter it now then follow the onscreen instructions.
