- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50, no connection with satelites anymore
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since 1,5 year I use an Orbi system with 3 satelites, never had any issues.
But out of the blue (I have not changed anything) I only have connection via the router and the 3 other satelites are gone in the netwerk.
Tried to reboot and reinstall but he cannot find the satelites anymore.
Any tips how this might be possible and how to reinstall again?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50, no connection with satelites anymore
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi (WiFi5 RBK Series). Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what firmware is on the router?
Firmware on the satellites?
What modem/gateway is the router connected to?
Are you re-syncing the satellites?
what error do you run into when re-syncing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! Hope I can answer them with my knowledge;
- The firmware on the router is V2.7.3.22
- Firmware satellites I can not see anymore, the app does not recognize them (see attached)
- Connected to the router of my provider (in bridge modus) via lan, lan and wifi via the Orbi router is working
- Not sure how I can re-sync, I tried via the sync bottom on the back of the units
- The app does not recognize the satellites anymore when I search for them
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello TimdF,
I understand you are having issues with your RBS50 syncing to your RBR50.
Please try the following:
1. First, Press and hold the Reset button until the Power LED on your RBS50 blinks amber.
2. Then, Bring the RBS50 and the RBR50 in the same room ( a few feet from each other).
3. Next, Press the Sync button on the router.
4. Then, Within two minutes, press the Sync button on each satellite.
Supporting Knowledge Articles:
RBR50 and RBS50 Reset: https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Syncing RBS50 and RBR50: https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Please let me know if this helps!
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can also hardwire the satellites into the router.
that should all you to access them and check firmware.
