Discussion stats
  • 5 replies
  • 2453 views
  • 1 kudo
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Initiate
Orbi WPS and Canon MG7570
My Canon MG7570 printer is unable to pick-up any signal from my Orbi router.  I have pressed the Sync button on the Orbi and then had my printer attempt to connect but it has failed each time I have tried.  The printer picks up wireless signals from my neighbours' appartments but nothing in mine...  Any suggestions?  (I am not tech literate so any suggestions will need to be written for a dummy!).  thanks
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 6
Accepted Solutions
Highlighted
Initiate
Re: Orbi WPS and Canon MG7570
thanks - after fumbling around and trying this solution I found elsewhere (set the 2,4 Ghz to Channel 10), I have got it working
Message 3 of 6
All Replies
Highlighted
Guru
What FW is currently loaded?
MAKE SURE your printer FW is up to date. Some printers wifi isn't the greatest. Does the printer have a LAN port or just USB port?
What security modes are you using on the Orbi? Try Disabling WPA temporarily on the Orbi. Then try to see if the printer will connect? If so, then try WPA and TPIK and test. Then try WPA2 and AES only and test.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 6
Highlighted
Initiate
Message 3 of 6
Highlighted
Guru
Interesting. Seems to be a printer issue. Normal channels are 1, 6 or 11.
Enjoy. Smiley Wink
Message 4 of 6
Highlighted
Just to confirm. I also had problems connecting my canon ip7250 to orbi using wps. Failed at least 3 times. Changed the 2.4Ghz chanel to 10 and it worked first time.
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 5 of 6
Highlighted
Guru
Be sure your printer FW is updated as well. Glad its working now.
Message 6 of 6
