Reply
Orbi and BT Home Hub 4
jules2323
Hi,
My setup consists of a BT Openreach DSL box which in turn is connected via ethernet to my BT Home Hub 4. I have disabled wifi on the home hub and plugged my Orbi in .. in router mode. Everything seems to work but as expected... it has created a second 10.x subnet for the Orbi network.
My question is, should I switch to access mode on the Orbi or better still can I just remove the BT Home Hub and plug the Orbi router into the Openreach DSL box to simplify things and have everything back on the 192.x subnet?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 4
Guru
Re: Orbi and BT Home Hub 4
If you can bridge the modem/hub so that the Orbi router gets a public IP address, this would be preferred. If not, then if the modem/hub has a DMZ feature, you can use this feature on the modem for the Orbi routers IP address it gets from the modem/hub and use the Orbi router in router mode instead of AP mode. This helps with double NAT conditions.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 4
jules2323
Thanks for the reply. Unfortunatly internet tells me BT Home Hub 4 does not support bridge mode. DMZ option looks limited.
So I guess, access point mode or I by something like a Netgear DM200 to replace the home hub 4?
Or live with the seperate subnet
Message 3 of 4
Guru
Give the DMZ a try...should work for Orbi in router mode.
I would check with your ISP first to see what they support or BYOM.
Some say that the DM200 is not a good modem.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 955 views
  • 0 kudos
  • 2 in conversation
Announcements
