Reply
Orbi setup —> no such file or directory
karibeany
Had configured with AC1750 cable modem router and worked without problem for 7 months. Suddenly unable to connect to internet with orbi. Have reset both modem router and Orbi. Internet connection is good (and even says so on orbilogin.net homepage). Firmware up to date. Finally reset Orbi router and with wizard setup, directs to routerlogin.net and says “no such file or directory.” Help!
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
AC641
Luminary
Re: Orbi setup —> no such file or directory
Have you tried logging-in from a computer browser and bypassing the App?
Message 2 of 4
karibeany
Yes, before resetting Orbi. Would say unable to find the server? But now that it won’t complete the setup wizard, can’t even access Orbi other than thru orbilogin.net. Any thoughts? I really appreciate the help
Message 3 of 4
Guru
Is the cable modem/router in router mode or bridged?
What mode is the orbi system using?
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1228 views
  • 0 kudos
  • 3 in conversation
Announcements
