- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi very slow or unreliable
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have since transferred my house and a external building (20 feet away) to the orbi Tri band system with the hub on the main floor (same as the old router) one satellite in the upstairs bedroom and one in the external building. Before I was just using 2 netgear WiFi extenders in the same locations and the modem (d-link dir-868l) from optimum and had low but consistent speeds. Now even though I the speed tests are saying I have doubled my speed it seems as though we keep getting kicked off the network on our devices (apple products mostly) and resolution on videos are low feeds. I have made no configuration changes to the Orbis. Any tips on how to fix these inconsistencies or low performance. Thanks in advance, we are stuck in our house these days so help is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi very slow or unreliable
What is the Mfr and model# of the ISP modem the NG router is connected too? The DIR-868L is not a modem. Good router though.
You may need the 50 series Orbi, as it seems to have more power and range over the 20 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? The DIR-868L is not a modem. Good router though.What is the size of your home? Sq Ft?
too many questions.....
