- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
RBK20W - How do I set it up with same SSID as my current router?
Here's what I bought it for...
Just switched internet providers and the new router is too weak to get to my outdoor camera consistently.
I went to Best Buy, told them the issue and they said to get the Orbi with the satellite, which would then allow me to extend my signal.
I set up the Orbi following the instructions on the App and now I have a separate SSID for it. So my question is, how can I set up this thing so that it just extends the signal of my new router?
Obviously I don't know very much about this stuff, but I can usually figure it out. Argh.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBK20W - How do I set it up with same SSID as my current router?
- You have to switch off the wifi of your existing router and use only the wifi in Orbi.
- If your existing router is not bridged (provides DHCP functionality), then you have to set the Orbi into AP mode to avoid IP address conflicts.
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
First, as mentioned previously, you need to take your existing router offline. Easiest way to do that is to turn it off and toss it in a drawer.
Next you need to change the WiFi name and password on your new router to the name and password that you already use. The simplest way to do this is to run the setup process from start to finish using the Orbi app on your phone, tablet, or computer. To start the process on a computer use the wifi name and password on the bottom of the RBR20 router.
If your network is up and running, but you just want to change your WiFi SID, use a web browser to connect to 192.168.1.1 which is the default for all Netgear routers. User name is admin, password is the word, password. From there you can configure pretty much anything, but start with the WiFi tab and just change your WiFi name and password.
I hope this helps.
- Allan
