- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remote management
- Mark as New
- Bookmark
- Subscribe
- Permalink
Remote management
When I try to enable remote managment I get the message, "this NETGEAR device is already registered with another account."
To the best of my knowledge I only have one NETGEAR account.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remote management
There are two kinds of "Remote Management" on the Orbi:
- The web interface has an option to activate "Remote Management", which opens port 8443 to the Orbi web server.
Anyone can then use a web browser to https://<public IP of Orbi>:8443 and "Voila", the web interface will appear.
Log in using the admin credentials, and it's just like being at home.
Of course, since port 8443 is well-known to hackers, the Orbi is immediately exposed to attempts to log in,
which fail because they do not know the password. My Orbi password is 30 characters long, which means
someone will have to try once a second for many (many) years before getting in.
But, it does fill up the Orbi log with "Invalid Login Attempt". - The Orbi App has a separate Report Management feature, which is based on the Netgear account that the Orbi was registered under. Sometimes people purchase an Orbi that was originally registered by someone else, then returned to the store (such as Costco or Amazon). This is a major annoyance because (a) the new owner is not able to register the product for support, and (b) the Orbi app is not happy.
(Sorry for the long response) My guess is that this Orbi was already registered to someone else. Were you able to register it on the Netgear web site, or when you configured it?
(or, I am "wrong again. dang!")
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did register my router.
I tried all my e-mail addresses; I don't remember which I used. None show the RBK 44.
They show the extra satilite I added.
Not sure of the next step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please do not post serial numbers of your Orbi system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not getting any help or follow up from netgear support!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @colehme
Please be informed that I removed your post as we do not recommend posting the device serial number on public.
I already take note of the device serial number. I will get back to you the soonest for update or next action.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
I'd like to!
How do I make contact with Blanca_O?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much.
I have purchase documents and registration statements that prove I bought and registered the router.
I actually provided them to someone named Armin (Case 4220386) but have not heard back.
I don't have knowledge of how the system works but wonder if there's a way to reinstall and set up the Orbi App with another e-mail address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Click on her user name and then select Send Privage Message.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
THANKS FOR YOUR REPSONSE. IT WAS HELPFUL. THE FOLKS AT NETGEAR SUCCESSFULLY PUT ALL OF MY PRODUCTS UNDER ONE E-MAIL ADDRESS. I AM STILL UNABLE TO ENABLE REMOTE MANAGMENT. I THINK IT'S STILL THE SAME PROBLEM, MY ORBI APP WAS SET UP UNDER A DIFFERENT E-MAIL THAN WHERE MY EQUIPMENT IS REGISTERED. HOW CAN I SET UP THE ORBI APP WITH THE CORRECT E-MAIL ADDRESS? I CAN LOG OUT BUT I CAN'T RESET. DO I START ALL OVER AS IF I'M SETTING UP A NEW ACCOUNT? IS THERE ANOTHER WAY TO CONNECT THE APP TO THE RIGHT EQUIPMENT?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please use the caps lock and ensure it's not enabled.
Thank you.
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
@colehme wrote:THANKS FOR YOUR REPSONSE. IT WAS HELPFUL. THE FOLKS AT NETGEAR SUCCESSFULLY PUT ALL OF MY PRODUCTS UNDER ONE E-MAIL ADDRESS. I AM STILL UNABLE TO ENABLE REMOTE MANAGMENT. I THINK IT'S STILL THE SAME PROBLEM, MY ORBI APP WAS SET UP UNDER A DIFFERENT E-MAIL THAN WHERE MY EQUIPMENT IS REGISTERED. HOW CAN I SET UP THE ORBI APP WITH THE CORRECT E-MAIL ADDRESS? I CAN LOG OUT BUT I CAN'T RESET. DO I START ALL OVER AS IF I'M SETTING UP A NEW ACCOUNT? IS THERE ANOTHER WAY TO CONNECT THE APP TO THE RIGHT EQUIPMENT?
