Collide9
Jul 09, 2019Aspirant
Router mysteriously stopped working in the night
My brother set up our Orbi router a few days ago and it was working fine. Last night when I went to bed it was working fine. I got up this morning and the router was flashing red and no internet. I connected my computer directly to the modem by ethernet and internet is fine (I'm on that now).
He registered it so I can't call support or anything. I have unplugged it several times and finally did a hard reset and was going to just reset it up completely. I downloaded the app to do the complete setup again and it wont show up on the wifi list anymore. I noticed online that if the satelites are solid magenta that it is not able to connect to the router. They are solid magenta. So does that mean that even the satelites arent able to communicate with the router? Therefore, the router is broken in some way? They should be able to connect to the router if they're in range no matter what right?
Is the Orbi system operating in Router or AP mode?- Collide9Aspirant
Thanks for replying,
I'm not sure how to tell what firmware is installed.
The modem says MODEL DPQ3212 and its made by CISCO
I don't know how to tell which mode it's in.
Ok, checking to see if there was a built in router at the modem. Your ok here.
Log into the RBRs web page and you'll see the FW version displayed on the upper right hand corner next to the log out button.
Has a full power OFF of the ISP modem and Orbi system for 1 minute then back on? Power ON the ISP Modem first, then the Orbi.
I would have your ISP check the signal quality and level up to the modem.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Collide9 wrote:I connected my computer directly to the modem by ethernet and internet is fine (I'm on that now).
I think we are suggesting rather than use the Orbi "app", that you connect the computer directly to the Orbi with an ethernet cable. Open a web browser and connect to the Orbi router. It should be at "orbilogin.com" or at 192.168.1.1. The Orbi web interface will provide information about the firmware, the modem connection, etc.
- Collide9AspirantThanks again for replying guys,
I tried direct hook up and going to those sites, no luck. It just gives me an error saying no internet. I don't know what I'm doing 😅- CrimpOnGuru - Experienced User
OK. How about this:
- Power off the Orbi, satellite, & modem.
- Power on the modem and wait until the lights settle down (can be up to 2-3 minutes)
- Connect the WAN (yellow) port on the Orbi router to the modem.
- Power on the Orbi router (not the satellite yet)
- Connect the computer with an ethernet cable to one of the Orbi router LAN ports.
- Find out which IP address has been assigned to the computer and what has been designated as its "gateway".
On Windows, from the Start button, open a command (DOS) window (by typing "CMD" into the box labelled "Search programs and files:) - In the command window type in "ipconfig /all" (no quotes)
On my computer, this is what I get:Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 20-25-64-0F-BA-CD
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, July 09, 2019 11:54:26 AM
Lease Expires . . . . . . . . . . : Wednesday, July 10, 2019 11:54:26 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
This says that the Orbi has assigned my computer the IP address 192.168.1.2 and that the Orbi is located at 192.168.1.1 (the Default Gateway)
Open a web browser on the computer and in the address at the top type in "http://<the Gateway IP Address>
This should bring up a login to the Orbi web interface. The user ID is always "admin" (no quotes) and the password is whatever you set the Orbi admin password to (not the WiFi password).
OK so far?
