Garethaowen
Jul 14, 2017Aspirant
Satellite won't connect after router firmware upgrade
After some help. My satellite uint (rbs50) will not connect to my main unit (rbr50) after I stupidly upgraded the router firmware.
Any idea how I can fix this?
First try restarting the satellite. If that doesn't work then just do a factory reset of the whole system and the main unit should find the satellite if it's close enough.
- LanderxApprentice
- GarethaowenAspirant
Hi, thanks for your reply. I tried restarting (several times!) and resetting the Satellite no joy. Was just gearing up to reset the whole lot this morning, plugged it all in and low-and behold the damn this just connected! There's 3 hours of my life i'll never get back.
Thanks for your respone though.
- LanderxApprentice
Glad it finally connected for you. It should now stay connected so it should be okay. Good luck.
