tucsontico's avatar
tucsontico
Virtuoso
Feb 09, 2020
Satellites won't display device name after update to FW 2.5.1.8.
Had a power outage which required me to reset all my IOT devices, etc. Decided it would be good time to update FW to 2.5.18 from 2.3.5.30. Went smoothly without factory reset. Good speeds and connections. However, both satellites now show "Unknown" in device name column. Not a big deal, since I have IP address reservations for all my 30+ devices. Wanted to see if there is an easier fix than a factory reset and a manual system reconfigure?
  • FURRYe38's avatar
    Not using a separated SSID name are you?
    Happen in a different browser?
    Diasy Chain enabled or disabled?
    You may need a factory reset. Some don't, some do.
    • tucsontico's avatar
      tucsontico
      Virtuoso
      1) Never used a separate SSID.
      2) Yep. Happens in Safari, Chrome & Firefox
      3) Daisy Chain is enabled due to my setup. 2nd satellite is in attached garage requiring daisy chain.
  • CrimpOn's avatar
    CrimpOn
    It has been some time, but I seem to recall having the same experience, "Oh, no.  I killed it."  Then after a while the device names appeared.  It could be that the router and satellite take some time to sync device information.  Before I did anything drastic (and time-consuming), I would go for a walk.
      tucsontico
      Virtuoso
      Did the upgrade three days ago. I've learned over the years I've used the ORBI to allow significant "settling time" before rushing to change anything.
      As I said it isn't big deal but I may resort to factory reset. If I only did satellites would that cause more issues?
      • CrimpOn's avatar
        CrimpOn
        A factory reset on satellite only is about the least disruptive thing you can do.  Nothing changes on the router, so there is no reconfiguration to do.
  • FURRYe38's avatar
    Let us know if a reset helps. Even if after giving time.
