- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Severe Packet Loss on Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
To whom this may concern,
I have purchased my Orbi RBR50 last year at a local BestBuy, since I needed a stable Wi-Fi extension that can extend my connection due to my router being at the opposite side of the house from where I use my PC.
The firmware version that I'm currently using is V2.7.2.104, which is up-to-date: the satellite model is an Orbi RBS50
I've been starting to have this packet loss problem since August of 2020; since then, I've tried restoring to older firmware versions (which did work for a short period of time) before I started to get packet loss again. I tried to fix it by updating my firmware again, but that did not work causing me to reset my router. After resetting my router, I updated it and it was working fine until last week. I tried using the same methods from before, but none of them would work; its as if the mesh/router became immune to those solutions.
The packet loss that used to happen was very minor and would occur every hour, whereas now, it occurs atleast every 5-10 minutes or when it's trying to upload or download more packets in games that are competitive. My download speeds are 330 MBPS, and my upload speeds are 16 MBPS, with my ping at 0 according to the SpeedTest website and the Orbi Netgear app. Anything like video streaming, online web calls or gaming causes the ping to rise from 20 to 80, and have consistent packet loss (around 60% to 95% packet loss). I cannot use ethernet from the RBR50 since it is located halfway between the house in order to maintain those high download and upload speeds. Bringing the RBR50 closer decreases the download and upload speeds, and moving it further reduces the bandwidth it has to my computer.
Any type of help would be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What are you testing with to check packet loss?
I'd turn OFF all RBS and all wired and wireless devices and test with just one wired PC connected at the ISP modem and check packet loss here first using pingplotter.com. Then test with the RBR in the middle.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Severe Packet Loss on Orbi RBR50
I agree with @FURRYe38 that identifying the source of the problem is essential. If the problem is external, then changing the Orbi cannot accomplish anything.
Assuming that the ISP connection checks out, there are two WiFi links to consider:
- The 5G WiFi backhaul link between Orbi router and satellite.
- The 5G WiFi link between satellite and PC.
The specific channel varies by Region. (See page 143 of the User Manual.) 5G WiFi is not affected by as many types of interference as the older 2.4G channels are (microwaves, portable phones, too many neighbors, etc.) In some locations, weather and military radar causes the Orbi to change backhaul channels.
Installing permanent ethernet cable if often impractical or expensive, but temporary use of a long ethernet patch cable can be useful for diagnosis. Amazon sells 100ft. ethernet cables for about $20US. Such a cable could be used, for example, to check the ISP service without moving the gaming computer. Could even run it outside the house.
(A tiny technical note: the description of "bringing the RBR50 closer..." probably refers to moving the satellite, not the router.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
After that process, I found out that it was my PS4 that was using up majority of the Wi-Fi bandwidth.
The games I used to benchmark the packet loss issues were Brawlhalla and Fortnite.
I will keep you guys updated if the packet loss issues occur again. Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW - V2.7.3.22 for both Router and Satellite.
Modem - Arris BGW210-700
I have been using pingplotter to check packet loss once I noticed it occuring.
I tested with my pc wired to just the modem and no other devices on the network for about an hour and ping stayed under 30ms with <1% PL. I then connected the RBR to the modem and hardwired the pc to the RBR and again experienced no higher than 30ms ping with <1% PL.
Then I added the satellite back into the mix. It is 1 floor directly above my modem and router and gave a blue ring following syncing. (It still shows a "config sync" status in orbilogin.net). However, I disabled my WLAN card in my pc and hardwired to the satellite to ensure no interference. I saw roughly 5-7 ping spikes a minute at hop 1 carried through to the destination up to ~2900ms. PL% was around 28% for the duration.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If your not seeing a GOOD status and only Config Sync, then the RBS is not fully syncing correctly. You'll need to remove the prior RBS connection from the RBR, apply the setting there. Factory reset the RBS and then attempt to re-sync it. IF this fails, you'll need to factory reset the RBR and RBS and setup from scratch.
