bboyd34
Aug 22, 2017Tutor
Streaming issues with Orbi
I have an ORBI router and satellite. Works great for the most part. However, two issues that creep up are streaming for Netflix and Amazon and some lag issues with my son's xbox. The router is upstairs next to my son's room and the TV is downstairs not too far from the Satellite. Streaming to the TV seems to happen quite a bit. Download & Upload speeds are good. Any suggestions/recommendations?
You said your TV is near the satellite. Wire the TV if you can. I have my TVs wired. I wire everything I possibly can and reserve WiFi for devices that cannot be wired. Wired always works best.
- martyfpLuminary
What issues do you have with streaming ? Does it not work at all or is it slow/breaking-up ?
- bboyd34Tutor
It works but in watching a show or movie there will be times (sometimes serveral times) where it will buffer and take time before it starts playing again.
- MarkC1024Luminary
Are you streaming via the TV's WiFi ? I had similar issues until I started running Netflix via my Xfinity box instead. I think most TV's have very poor WiFi chipsets.
- st_shawMaster
- bboyd34Tutor
Dang so obvious I'm ticked I didn't think of it. I was thinking you could only wire to Router for some reason. I'll try that, thanks!!!
- Splunge1Aspirant
I have the same issue, and I am directly wired to the router. Every time I play a YouTube video or stream netflix, the video starts for a few seconds, then pauses while it buffers. Every time. This is really annoying and didn't happen with my old router. Help!
