dtv757's avatar
dtv757
Unable to log on to website
Good Morning,
Recently i have been unable to log into WWE.com via my orbi.  I get the the log in page but unable to press login via multiple browsers (chrome, edge, etc  using WIndows 10 or via browsers ipad and iphone) . On devices already logged in such as Xbox it just spins nothing happens.
I have master reset the orbi RBR20 and reset my modem.   If i plug ethernet directly to cable modem or use my cell phone as a mobile hotspot I am able to log in and watch the content on WWE on mulitple devices no issues.  I even plugged in an older non netgear router and was able to log into wwe and view the videos.
i tried the steps listed (https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125 ) but still unable to log in.
any other suggestions or caused as to why this would occur??
after the master reset i made sure no content filtering or blocking was on . the only adjustment i made was the Netgear link above (Click on Service Type DropDown and Select HTTPS) which did not fix the issue.
Thanks for any suggestions.
  • So if this is happening with a non Orbi router, then there is something going on at the ISP service, ISP Modem or your PC/Device that needs to be looked into. This doesn't seem to be a Orbi or a non Orbi router issue.
