Reply
Highlighted
Wifi booster for Huges net Satellite
Will this work with. Hughes net Gen 5
Message 1 of 13
Accepted Solutions
Highlighted
Re: Wifi booster for Huges net Satellite
Does the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
Message 3 of 13
All Replies
Highlighted
the orbi system will work with anything that doesnt need a modem , in cases where a modem is needed it need to be ether bridged or the orbi system ran in ap mode
Message 2 of 13
Highlighted
Message 3 of 13
Highlighted
no the orbi hooks up to an ethernet port on your upstream modem in your case the huges modem , the huges would still work as normal and you would just disable its wifi then connect the orbi system and run it in ap mode
Message 4 of 13
Highlighted
Thanks I'll order one or. Pick it up at Walmart. I believe I understand what your saying.
Message 5 of 13
Highlighted
im assuming the huges modem is also a router , can you link to its web page for me if you dont know
Message 6 of 13
Highlighted
Yes I can get on their web site .
Message 7 of 13
Highlighted
Their router has my computer, phone both plugged in to it . Not very big
Message 8 of 13
Highlighted
so its a router as well , in this case the orbi would need to be ruun in AP mode
Message 9 of 13
Highlighted
AP mode , does it still plug in with earthnet cat 6
Message 10 of 13
Highlighted
Would another router be better ?
Message 11 of 13
Highlighted
yes
Message 12 of 13
Highlighted
depends on what you are after
wifi coverage wise you wont get better in a standard wireless router no matter how good it claims to be
feature wise you could prob do better with a wireless router but the wifi wouldnt be as good
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 7397 views
  • 0 kudos
  • 2 in conversation
Announcements
