- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Will installing too many satellites do more harm than good? More coverage than necessary overkill.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I just moved into a new 2-story house that's 2600 square feet. Typical suburban home. Ideally, I should get a one router/one satellite system like the RBK40, RBK22, or even the RBK50.
However, I'm looking at larger systems for sale like the RBK53 which is one router/two satellites and even the RBK44 which is one router/three satellites. And these are rated to cover 7,500 to 8,000 square feet respectively.
My question is will installing a system that's rated to cover more area and installing that into a smaller home do more harm than good? Will installing too many satellites when you don't need them give you better coverage or is it counterproductive?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: Will installing too many satellites do more harm than good? More coverage than necessary ov
There are only a limited number channels available, so installing too many satellites competing for the same frequencies will surely hurt the performance, if they interfere with one another.
If they can still reach the router, you could lower their transmit power, which I have done even for my one satellite, which is running on wired backhaul and thus doesn't need to connect to the router (in AP mode, though) wirelessly.
I'd start with the minimum number of APs and see, if you can get away with that and only add more, if really needed.
Just my 2c, of course.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Will installing too many satellites do more harm than good? More coverage than necessary overkil
I have the one router and satellite and it covers my 5000sq ft home.
Seen others with up to 3-4 satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can lower the power on the Orbi router is all. There is setting under Advanced/Advanced Wirelesss. I don't believe this does anything for the satellites. Yes, reducing the power, you'll have to move the satellites closer as the foot print coverage will be effected.
I have a 5000sq ft home and use only 1 satellite. 40 feet in between. Full power. Great coverage, range and performance.
@Rickharrill wrote:
How do you lower the power of these units? I'm assuming that lowering the power would reduce the sq ft coverage. Because my home is nowhere near the 5000sq ft my units are rated for, I'm hoping to be able to customize the signal to better suit my needs. My main goal is to have a satellite in my son's room, for a hard wire to his gaming system, which is on the same floor opposite side of the house as the router. I have the router and 1 satellite ac3000 system (5000sq ft). Perhaps the system rated for 3500sq ft would be a better fit for me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's 1 router & 6 satellites! Brilliant coverage. House including garden size = 799 sq.meters
There is a trick to setting them up though. See my setup post.
Hope above info. helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Screenshot of my setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've got one router and two satellites in a 2000 sq ft house, no issues.
Laid out like an "L" with the router in the middle. Get full speed to the street and out to the edges of my yard. Works fantastic.
