- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
I setup the orbi with wired backhaul so I use one port to connect with the orbi router. But after I connect my device(PC) to the other port, the whole orbi system is down. I cannot get online anymore. So I wander if the two ports are auto sensing?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
They are...
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Ensure the cable between the RBR and PC is of good working quality. CAT6 is recommended. Swap cables for testing.
Try different ports.
Try a different PC.
Are you connecting to the RBR or RBS?
Disable Daisy Chain if you have the RBS connected ethernet to the RBR.
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
They are...
Try a different PC.
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: auto sensing Ethernet port?
Thank you, please see my setup below
What Firmware is currently loaded? Latest 2.3.5.26
What is the Mfr and model# of the ISP modem the NG router is connected too? Netgear CM500
Is the Orbi system operating in Router or AP mode? Router
What is the Mfr and model# of the ethernet switch if one is in the configuration. Netgear GS308P
Ensure the cable between the RBR and PC is of good working quality. CAT6 is recommended. Swap cables for testing. OK
Try a different PC.
Are you connecting to the RBR or RBS? RBS, RBR connected to the switch, and RBS connected to the switch
Disable Daisy Chain if you have the RBS connected ethernet to the RBR. Will do
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try connecting to the RBR with out the switch in the mix.
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
disabled Daisy Chain and it worked very well! Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Enjoy.
RBK50 v2.7.2.102
