- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
changing orbi wi-fi channel
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to change the channel of my Orbi system to move it away from a neighbor's wi-fi. How do I get into it to change the channel?
Stephen
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: changing orbi wi-fi channel
If you remember the administrative password (not the WiFi password), you can use a web browser and go to http://orbilogin.net. There is a menu item "Wireless" on the Home Page where you can set the chanel for 2.4G and 5G WiFi.
Please understand, all modern WiFi systems constantly scan the enviroment and adjust to find the best channel available at the time. You may find that as soon as you "move" your Orbi, the neighbor's WiFi may move as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
@Stetrekve wrote:I need to change the channel of my Orbi system to move it away from a neighbor's wi-fi. How do I get into it to change the channel?
Stephen
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When we change the 2.4 GHz Channel from 9 to 11 and click on apply button, an popup says
"Per Wi-Fi Alliance guidelines for 40 Mhz and 20 Mhz coexistence, even if you select "Up to 400Mbps" mode, your product’s service rate might drop to 20 Mhz. This typically corresponds to 192 Mbps performance." close button.
It takes us back to Wireless settings again. No matter what number we choose the popup keeps coming back and we can't change it. What are we doing wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Navigate to the Advanced Tab, Advanced Settings (bottom item), Advanced Wireless Settings.
Notice that the option Enable 20/40 MHz Coexistance is checked. (Here on my Orbi it is not checked.)
Enabling this option allows devices to bond two 20MHz channels together to get higher throughput. However, when a device that is capable of only using a single 20MHz channel is active, the entire channel constricts to 20MHz and devices that are capable of using the full bandwidth are not allowed to. I find it very confusing to read about:
https://robotpoweredhome.com/20-40-mhz-coexistence-netgear-router/
long discussion on Redit:
https://www.reddit.com/r/orbi/comments/johuh7/should_i_enabledisable_2040_mhz_coexistence/
- Mark as New
- Bookmark
- Subscribe
- Permalink
p.s. On my Orbi, the channel changes either way. Takes bloody forever to do so, but it does change.
