- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
connecting orbi to a switch vs directly to dsl modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My current connection: dsl service comes into house directly into a filter, then 2 outs (one to phone service throughout the house and one to dsl modem). my dsl modem is then connected to a 16 port switch (where wired connections from other rooms are connected). I then have a wireless access point connected to my switch - this allows wireless connection to my internal network as well as the internet. Was thinking about replacing the access point with the orbi (which i bought today). Finally, my question: can i connect the orbi to my switch instead of to my modem so that it can function as an access point to my wired network just like i'm configured now?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, and set Orbi to AP Mode. If you miss this during setup, you can change it in the Orbi ADVANCED page in Advanced Setup.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: connecting orbi to a switch vs directly to dsl modem?
Yes - in AP mode, that's exactly how it works. It doesn't matter if it's connected directly to the modem or a switch off the modem.
Your other option is to switch your modem to bridged mode and use the Orbi as both your router (firewalling, etc.) and your AP.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
Right on. Connect 16 port switch to Orbi, and Orbi to modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks - so can i connect the orbi to the 16 port switch only (no direct connection to the modem - only through switch) just as i do now with the wireless access point? Am I following you correctly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
