- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
outdoor receiver antenna for orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a rbr50 ac3000 with one inside satellite and one rbs50y outdoor satellite. The system works well and I can get high speed internet from anywhere in my one acre lot. I have a second block building about 75' from the outdoor satellite and cannot get a decent signal from the outdoor satellite. Short of purchasing another expensive rbs50y can anyone recommend a receiver antenna I can mount on the building that will work with the rbs50y? I assume i will need a router inside connected to the antenna to provide wireless throughout the building. Any special requirements for the router? Any help is certainly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: outdoor receiver antenna for orbi
From what I can see, Netgear does not sell an outdoor rated WiFi access point besides the RBS50Y, which as you have noted is expensive.
There are solutions which will provide coverage to the block building, but there are no solutions that will integrate with the Orbi.
Would there happen to be a window in the block building that faces the outdoor Orbi?
If so, you might consider placing a WiFi extender (any brand) in the window where its antennas are visible to the Orbi and also visible to devices within the building.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@pryner wrote:
I have a second block building about 75' from the outdoor satellite and cannot get a decent signal from the outdoor satellite. .
That's a strech for consumer grade wifi.
Are the buildings on the same power circuit?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually they are on separate electrical systems. Each has its own meter and main box
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was entirely serious about "is there a window in the building that faces the RBS50Y."
This is one situation that I think calls for a "Range Extender". They are widely available and dirt cheap.
Netgear's EX3700 is $30: Amazon Link
TP-Link's RE220 is $23: Amazon Link
TP-Link's RE450 is $59: Amazon Link
The more they cost, the higher the throughput.
They can all be programmed to have the same WiFi name/password as the Orbi. All are designed to be connected to a standard electrical wall outlet. I would use an extension cord and stand it in the window facing the RBS50Y. Window glass typically does not impede WiFi signals as much as concrete block. Every device inside the block building should "see" the antennas, as should the RBS50Y.
I'd spend $30 to try this if the alternative is 10 times as much.
Of course, no window = "sorry. My Bad."
- Mark as New
- Bookmark
- Subscribe
- Permalink
no direct facing window. One faces south almost purpendicular to the satellite which is to the west. There is one west facing window but it is 20' to the north of the satellite and more than 30' away from the satellite. I like the idea though and the cost is low enough to give it a try.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please report what happens. 30ft. in open air is not such a big deal if the RBS50Y is currently covering an acre. The key is that the antennas have to be visible to the Orbi and to the inside.
