- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Create Port Based VLAN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everybody, I am trying to create something like port based vlan on a gs748t since it does not seem to support port based vlans. What I want to achieve is to have multiple port groups isolated from each other.
I tried taking port 3-8 and set them to vlanid 178, then also assigning them pvid 178 but it does not seem to work.
I have been trying for hours and I am really at loss here. Somebody got a clue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Create Port Based VLAN
With g3..g8 not member of any other LAN (check the all), this looks Ok to me..
For a DMZ, and considering you might use the switch for different security zones, I would suggest to allow untagged frames.type for these ports only, instead of admit all.
Can the problem you facing more related to the router, port forwarding, or the like?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is also no port forwarding involved, I directly connected a cable from the router to the port. See this more as a propetarian DMZ, g3 to g8 as a standalone switch.
g3 to g8 are not part of any other LAN. I can not select untagged only since this option does not exist.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, this is what is configured now.
OK, this makes up a dedicated network (except of STP/RSTP which does span al VLANs)
Correct - ignore my bad advise, sorry please.
