miltonreg
Feb 24, 2022Aspirant
GS105PE default password isn't working
Hi,
I recently purchased a brand new GS105PE switch, but I can't login to the admin page. According to the manual tha came with the device, as well as the one I found on the support page, the default password is password, but it isn't working.
Any advice?
Thanks.
- Marc_VNETGEAR Employee Retired
Yes, you are right the default password should be password. Have you tried using a different browser? or clearing the web data?
If you have already tried using a different browser, try doing a factory reset on the switch and then try to access it again.
HTH
- miltonregAspirant
Yes, I tried different browsers on normal and private/incognito mode, but none of them worked.
I can give it a try reseting the device. Do you know by chance the link to the instructions of how to do it?
