reynolds087
Aug 06, 2022Follower
GS108E - Disable Web Interface on Specific Ports
Hi,
I'm trying to limit web configuration of the GS108E to only one of the ports. Is there a way to do this? I tried only applying PVID 1 to a single port (assuming web configuration may be limited to VLAN 1), but on any port, it seems that as long as I configure the LAN on my laptop to the same subnet as the IP of the switch, I can reach the web console. Any insight would be appreciated. Thanks
1 Reply
Can't no such feature available. Some Plus switch model variants allow to restrict the IP to single address (or subnet unless I'm wrong). The access to the config interface is not bound to a specific port or to a select VLAN, too.
