Reply
GS110TP deactivate PoE over SNMP for specific Ports
harry7922
Guide
Hi everyone,
I bought a GS110TPv3 Switch because I read that I can disable PoE for single Ports via SNMP.
Now I downloaded official MIBs for that switch but didn't find right OIDs.
Can someone please support?
In other threads a special MIB was provided for download - but these downloads expired.
Thanks in advance!
BR,
Harry
Model: GS110TP|ProSafe 8 ports gigabit PoE smart switch
Message 1 of 7
Accepted Solutions
schumaku
Guru
Re: GS110TP deactivate PoE over SNMP for specific Ports
The POWER-ETHERNET-MIB is a standard MIB, starting from the OID .1.3.6.1.2.1.105.
The OID .1.3.6.1.4.1.4526 on the other hand is a Netgear private MIB - this is not the POWER-ETHERNET-MIB.
The problem we're facing is a very inconsistent set of OIDs implemented on switch series which should be very similar - why ever, the popular and powerful Netgear private MIB seem to be missing on this model.
Message 4 of 7
All Replies
schumaku
Guru
Link, context, ... please.
Message 2 of 7
harry7922
Guide
Sorry! Forgot to add a link. Maybe I misunderstood something.
Link:
https://community.netgear.com/t5/Smart-Plus-Click-Switches/MIBS-file-download-for-GS110TP/td-p/15513...
Today I did a lot of research. But didn't find a solution.
Hope someone of you NETGEAR experts can help.
As I told, I bought a GS110TPv3 and this is supporting "POWER-ETHERNET-MIB".
I opened my MIB Browser and loaded the actual MIB (v5.4.2.16) from NETGEAR support site. When trying to get TableView of "pethPsePortTable" (OID:  .1.3.6.1.4.1.4526.11.16.1.1) of "powerEthernetMIB" no table is delivered from switch. SNMP connection works. other MIBs I can access and get results from switch.
Can anyone support?
Thanks in advance.
Best regards, Harry
Message 3 of 7
schumaku
Guru
Message 4 of 7
harry7922
Guide
Thanks for your help!
The problem was the newbie-user an not the device!
BR
Harry
Message 5 of 7
schumaku
Guru
Harry,
For completeness, have you discovered the SNMP MIB for enabling/disabling PoE on the GS110TP, and has it worked as per your demand?
TIA,
-Kurt
Message 6 of 7
harry7922
Guide
Hi Kurt,
yes that's right in the powerEthernetMIB the OID 1.3.6.1.2.1.105.1.1 (pethPsePortTable) is the starting point.
With this you can choose the correct port and enable/disable "pethPsePortAdminEnable". Port 2 for example is OID: 1.3.6.1.2.1.105.1.1.1.3.1.2
Thanks again!
BR
Harry
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2341 views
  • 1 kudo
  • 2 in conversation
Announcements
