securutybyte's avatar
securutybyte
GS308E & Unifi AP vLAN
Hi
I have a Unifi AP and I am trying to assign vLANs to my wireless networks. I am using a Netgear GS308E smart managed switch and an Untangle router.
The router is plugged into port 1 of the switch and the AP is plugged into port 8. I have a wired vLAN (vLAN 20) on port 2 for POE security cameras, which works fine. However, I am struggling to get my head around how to achieve the same with the Unifi AP. I want to assign the vLAN based on the wireless network SSID, so I guess the switch needs to pass the vLAN through or something?
The main wifi network (without a vLAN) works, but if I specify a vLAN then the device is unable to get an IP.
I have attached some diagrams. Please can someone kindly advise what combination of Tags/Untags/blanks I need on vLAN30 in order for devices to connect to the 'TEST IOT' wireless network?
Note, I have not configured any 'Networks' in the Unifi controller as I believe these are only required if you have a Unifi switch or gateway.
Thanks
Mike
  • securutybyte,
    Welcome to our community! :)
    It seems that you are having issues with the VLAN configuration of your switch going to your AP. I saw that your VLAN 30 doesn't have any members. You must tag the port of the switch on port 8(AP) and also your uplink(port 1) for VLAN 30 and leave the PVID to 1.
    Basically, if the device is VLAN aware, you always need to tag the port in order for the VLANs to pass through properly. We only use Untag for devices that don't support any VLANs.
    I hope this helps :)
    John
    NETGEAR Community Team
ProSupport for Business
